1962 johnson 28hp
onelostrn
I was just given a johnson 1962 28 hp model rx10. Does anyone have a wiring diagram for this motor? I have no spark when it is pulled over.
Thanks
Daviet
Re: 1962 johnson 28hp
The ign system is under the flywheel. Pull the flywheel and check the coils for cracks, if cracks are found replace the coils. Check the points, clean and regap to .020". Make sure the flywheel taper and flywheel are clean and the key is in good shape, reassemble and torque flywheel, and check spark and see what you have.
jasper60103
You really need to read the rules, jasper.
