dstroud1987
Thread starter- Joined
- Feb 23, 2012
- 122
hey guys, I've been working on fixing up and old fiberglass boat that i bought off of kijiji. I was supposed to do some fiberglass work this weekend, but it was kind of cold outside so i decided i would try and finally start the old motor it came with. Its a 1962 johnson 40 hp and it hasnt started in at least 2 years. When i took the lid off of it there seemed to be some sort of nest in there made from the foam thats on the inside of the cover. So i decided i would clean the nest out and throw some new plugs in it and see what happens. It took a little while and some loud bangs but she eventually fired up. Seeing as this is the first time i've ever seen a boat motor running in person, i thought it would be a good idea to post it here and see what you guys think of it.
It seemed to idle quite well, and it was spitting water from the pee hole, so i know thats a good sign. I just had a couple of question for you as well.
When i put it into gear the motor seemed to move quite a bit.. just seemed a little violet to me lol i wasnt sure if it was supposed to be really noticable when it kicked into gear, or more suttle. It went in out of gear thought a problem so im leaning towards believing that that was normal.
Also when i finished running it there seemed to be a lot of oil and/or gas in the bucket of water. Ive heard that these old motors tend to do that.. but when i stopped running i wasnt even able to see past the surface of the water because it had so much crap in it.
anyways, here is a video of it running.. let me know what you guys think.. and if you can answer my questions or give any tips or advise, that would be awesome.
