1962, MERC--9.8 hp. Impeller change- so where is the pee hole?
zolt
As title says/asks, where is pee hole? is it the little exh. outlet just under power head at back> or am i just really blind? anywhooo, how much cshould be coming out when idling, etc.... the serial no. is 1551501,
any help is greatly appreciated,
thanks,:confused:
Texasmark
Re: 1962, MERC--9.8 hp. Impeller change- so where is the pee hole?
I don't know when Merc introduced the pee stream to ensure that your water pump was pumping water up to the powerhead.
The hose barb that feeds it is about 1/8" pipe thread to about 1/8" hose. The pickup is usually either off the exhaust manifold water jacket or the water jacket that covers the tops of the pistons.....on V higher hp engines it can come out the top of the block if not plumbed off the tstats.
The outlet is usually on the Starboard rear of the engine, in the lower cowling and angled down at about 45 degrees, so that the operator of the engine can see it as they usually sit on the starboard side of the boat (nowadays).
HTH,
Mark
Bridar
Starboard side, near the back. It's hard to find unless there's water coming out the hole.
1946Zephyr
Sometimes those get blocked and you need a small wire to poke in there to get it flowing again.
Laddies
Banned
On a 1962 9.8 or 6 the telltale is on the port side of the engine pan just ahead of the center mounting stud and nut. Why do people anwser threads that don't have a CLUE?
Bridar
Is that a question or just your arrogance showing?
Sorry Zolt, I wasn't guessing. My old 9.8 does have the hole on the starboard side, but because mine and your's are a couple years apart, there may be subtle differences.
Laddies
Banned
Why do people answer threads that don't have a CLUE?
Just a comment on people posting without giving a knowledgeable answer, that is why most people ask a question for a knowledgeable answer, not a answer that is just a guess or someone padding posts.
