Adalrik
Thread starter- Joined
- Sep 29, 2020
- 8
Does anyone know the proper way to change out the shaft seal part #58 in the diagram at marineengine.com
from what I can tell, I need to pull the needle bearing #59 to get to it and I will need to replace the needle bearing also as it will be destroyed.
Also, is it possible to add a 2nd shaft seal?
Thank you!
Thank you!
