dougandmel
Thread starter- Joined
- Aug 21, 2007
- 25
I have the above outboard. It doesn't have the traditional "peeing" tell tale out the back. It spits water through the exhaust port above the water line. I also see two holes (one on each side of the exhaust housing) just above the lower motor mounts that water comes out of. Are these holes considered the "tell tale" for this motor? I was thinking of tapping into the thermostat cover and adding a "peeing" tell tale out of the back of the motor housing. Any thoughts on this, or are the two holes on the exhaust housing good enough to watch the water pump's performance? Also, If I add the tell tale, would the impeller still be able to move enough water to cool the motor and pump out of the "tell tale"? Thanks in advance.
