My son and friend picked-up an aluminum 14' for a very good deal. I'd thought I'd give them my old Sportwin that was moth-balled about 6 years ago. Engine popped on 2nd pull, and was running by 10th pull. Ran very well, and did a decarb on it. Seems to idle down fine in the tank. I went to change the lower unit oil and found white foamy oil. Definitly water.
I did some seaching in this forum and found the most common cause is not replacing the gasket on the fill screws. Well, I'll try that, but that would be too easy and lucky for me. Assuming that is not it, is a seal kit the next thing? On this outboard it looks like this does split along the propeller shaft. Unlike new outboards, can a seal kit be put in without special tools? And given the age, where is the best place to order these from?
Its been awhile, and haven't found my old manual yet, would like to confirm my old memory:
- Lower unit oil takes a special type C
- Fuel bowl while running does not stay filled (1/4 or less) is normal
- gas/oil mix ratio is 24:1
- are common parts, impeller, carb kit, fuel pump kit, points/condensor, still available?
Thanks for any help.
PS: It was nice to see an ole engine fire back up, like it was put away a couple of months ago.
