1963 10hp throttle lockout
ward cleaver
I have a 1963 10hp Evinrude that won't throttle up when in either forward or reverse position because the throttle lockout is not disengaging. With the motor not running, I can manually pull out the lockout part to allow the throttle to advance to maximum in reverse and forward, but it won't stay in that position. Is there an adjustment I need to make, or is the lockout bent in toward the flywheel?
oldcatamount
Re: 1963 10hp throttle lockout
Is there a ciol spring about 2" long that pushes the lockout arm away from the block when shifted into gear?
ward cleaver
There is a spring at the top of the arm but I was thinking that is pulling rather than pushing.
edit: #30 in the drawing
