Watermann
- Joined
- Jan 12, 2013
- 13,845
You'll need to do a dry fit first once the holes are all transferred to the new skin, drain tubes, motor, side brackets and if your model has a Z bracket at the bottom. Then most of your questions about fastening should be answered.
For the surface area, I would clean both with AL brightener and use a 3M scrub pad to make sure the surface is ready to accept the 5200. Sand any raised areas smooth too. I wouldn't prime the metal it would only add a source for bonding failure.
