KewlBird
Thread starter- Joined
- Oct 6, 2007
- 247
Hi everyone this is my first post and I want to say that this is a great website. Already found a ton of information.
I have a 1963 Johnson 40hp Sea Horse Electramatic, I just purchased the boat/motor with some work necessary. It appears that some things were left unfinished when the motor was put in, for instance there is no way to put the motor in gear (no electric control for the shifting), easy fix for me now that I found this website and found electric diagrams.
After cleaning the carb and getting the old fuel out I got the engine to start with starting fuel. The engine will only run when the throtle is at least half way open (I had to by pass the safety switch in order to start with the throttle that high up). Once it gets going it will run but is blowing out of carb every 2-3 seconds (backfire). If I rev it higher it will not do it so much. If I try lower the throttle to normal idle speed it will stall out. Any suggestions?, Looking at a wiring diagram the plug wires seem to be hooked up backwards (Look at the picture), I tried switching them but the motor wouldn't run. There is also one hose coming from the side of the carb that is not hooked up (it is blocked off by a bolt, see picture). Let me know if the plug wires are ok and if that hose is neccassary to be hooked up to something. Any help is appreciated. Thanks.
