1963 40hp evinrude run like a 10 hp
Hooty
Re: 1963 40hp evinrude run like a 10 hp
You probably have a cylinder that's now producing power. <br />Check the trouble shooting charts in your manual.<br /><br />c/6<br /><br />Hooty
Frank Martin
take the recoil starter off there is a inspection cover remove it look in if coils are cracted take flywheel off replace coils points and condensers and retry
JB
Probably be a good idea to find out which cylinder is dead and whether it is a carb problem or an ignition problem before you do anything else.<br /><br />Most likely is one of your magneto circuits is bad. Could be points, condenser, coil, plug wire or plug.<br /><br />Good luck. :)
