TX Duck Guy
Thread starter- Joined
- Aug 1, 2004
- 37
I am checking out a motor that was given to me. The model # is: 40373 DB<br />So far I have'nt found any excessive wear when I pulled the lower unit to check a few things. So, here's what I need help with:<br /><br />1) I have searched the forums and found a few different post on electric shift. None seem to relate directly to my model. I have two wires (green and blue) exiting the LU. As I spin the input gear by hand the gears inside the LU just spin. Is this not supposed the lock into forward with no voltage to either wire (as a fail safe)?<br /><br />2) If not, how does the selectric shift work on my motor? (Green FWD, Blue RVS?)<br /><br />3) There is a mounting bracket at the top of the engine. It looks similar to the starter bracket but there is nothing currently installed here. Possibly something driven by the flywheel goes here. Am I missing a part?<br /><br />4) SCEMATICS please! I have'nt gotten my maintenance manual yet and I'll need to rewire this thing.<br /><br />5) The remote control looks pretty dicey as far as the shifting switch goes. What are my options here? The switch appears to work according to my ohmeter, but have no way to know if it is right. If necessary, can I wire in another kind of switch. If so, how can I retain the safety interlock?<br /><br />6) What other kinds of tests can I do initially? I have a compression tester (lower unit removed but power head is complete on my stand), dial calipers, etc. I just want to ascertain the condition of this motor before commiting to it.<br /><br />Thanks for your help in advance!<br />I know this is a lot, but I just want to ascertain the condition of this motor before commiting money to it.
