IronWill
Thread starter- Joined
- Dec 29, 2009
- 51
Hello Fellas?.me again?
I have a 1964 RDSL 40hp long shaft motor. I?m swapping out a 1963 RDS 25D short shaft lower unit to make the 64 a short shaft motor. The 64 lower case is pretty dinged up and has a broken fin and the 63 case is in good shape except for one thing?
?the needle bearing Ref. # 32 needs to be replaced. I figured while I?m there I?ll replace Ref # 38 bearing as well. These bearings are press fit so I?ll have to take it somewhere to get the work done?errr?
?here?s where I need some help. I have a parts catalog for the 64 model. I need to know if the bearings are the same part # on the 63 model. The 64 catalog shows Ref. # 32 is 376856 and Ref. # 38 is 376858. Is there someone that will be so kind as to verify that these bearings are the same used on the 63 model?
I found the parts on eBay and will like to know if they are correct before I pull the trigger?
Thanks a ton again folks?
