1963 650 Merc bearing carrier
kbh121956
Hello all, Looking for information on the tool to remove the bearing carrier assembly. I have one for the mercruiser alpha outdrive but it's too large. Anyone have a part number for the tool or a link? Thanks!
The Force power
To remove the retaining-nut, you can use a dull chisel and carefully tap against the notches take turn using a different one randomly (make sure you have bent the tap over)
If....its never been replace it will be a cast-aluminum kind, otherwise plastic and can just break away
I made my own similar to this one
I made my own tool
k8uiTeXEBW89X9GM3lPvNkeHfeR_1KUh2-nwU9vy8Jf3Hs4p6M1w1qsme_oAW_3918NjRwTUI7WbbzrvZe-NAwtn36Lm
