1963 motor has not ran in about 10 years I guess all kinds of parts will need replaced
E evrcare Cadet Joined Jul 9, 2006 Messages 7 Jul 15, 2006 #1 1963 motor has not ran in about 10 years I guess all kinds of parts will need replaced
D dsinger Chief Petty Officer Joined Aug 6, 2004 Messages 424 Jul 15, 2006 #2 Re: 1963 75 horsepower awakening an old motor Maybee not do it right and you will save big bucks
tashasdaddy Honorary Moderator Emeritus Joined Nov 11, 2005 Messages 51,019 Jul 15, 2006 #3 Re: 1963 75 horsepower awakening an old motor hope you got all that info i sent. awakening, oil cyls, before try to start, comp check, spark check. waiting results.
Evinrude Boater Lieutenant Junior Grade Joined Jul 6, 2004 Messages 1,147 Jul 15, 2006 #4 Re: 1963 75 horsepower awakening an old motor You might want to replace the water pump before starting it. There's nothing worse than hearing it jump to life only to have it overheat and spit out the impeller blades.
E evrcare Cadet Joined Jul 9, 2006 Messages 7 Jul 16, 2006 #5 Re: 1963 75 horsepower awakening an old motor tashasdaddy said: hope you got all that info i sent. awakening, oil cyls, before try to start, comp check, spark check. waiting results. Click to expand...
E evrcare Cadet Joined Jul 9, 2006 Messages 7 Jul 16, 2006 #6 Re: 1963 75 horsepower awakening an old motor I did get all of that info thanks for the help I have lots of reading to do and then alot of work after that but it will be time well spent
