1963 Evinrude fule pump leaking?
medic10928
I have a 1963 Evinrude 40 horse motor that I am trying to keep going. Right now my question is: There is fuel coming from a hole in the rear of the fuel pump every time I pump the primer bulb. It then leaks down into the motor. What is this hole for? Is this normal? The hole is about the size of a pencil lead and is directly in the center of the back of the fuel pump. Thanks
Chris1956
Re: 1963 Evinrude fule pump leaking?
It sounds like you need a fuel pump rebuild kit. Is it the original fuel pump with the glass sediment bowl? Kits should be available at a dealer.
medic10928
yes its the original with the sediment bowl. So what is the hole for?
medic10928
The link to the pump above is a differant fuel pump than mine. Will it still work?
