1963 evinrude spedifour 75hp. no spark
ctaylor2069
Re: 1963 evinrude spedifour 75hp. no spark
OK will soak them and let u know. Do u know where I can buy parts if I need them
Joe Reeves
(Replacing Screw In Type Plug Wires)
(J. Reeves)
It's next to impossible to find replacement spark plug wires for the older engines that have the brass screw in terminals which screw into a distributor cap. The solution to correcting a spark plug wire (or a coil wire in some cases) of this type is as follows:
Purchase however many brass screw in terminals as you may require (OMC Part #510364). Price is about $1.75ea. If you also need the spark plug boots and the spring terminals that connect to the spark plugs, purchase them also (OMC Part #581027). This includes one boot and one spring connector. Price is about $3.25ea.
Purchase whatever amount of spark plug wire you need. Be sure to purchase the kind that has a steel twisted wire leading through the center of it....... not the carbon type plug wire that many automobiles now use.
Have a piece of 2"x4" handy or any other piece of wood that will suffice, and if you have a vise, clamp that piece of wood in it. Punch or drill whatever amount of holes you want in the top portion of the wood...... you want a almost perfect size hole that you can easily screw one of the brass screw in terminals into. I normally use just one hole, reusing it as many times as necessary. The terminal should screw or push in easily so that removal is just as easily...... but you do want the terminal to be held securely.
Using your old plug wire, cut the new wire to a length about one inch longer. If you have no old plug wire, just make sure that the wire is longer than you'll need as you can trim the other end later. The end that the brass screw in terminal will go on... cut the insulation back about 1/4". With your finger, seperate the wire strands so that they are seperated and angled off at about a 45? angle when viewing the wire being held straight up. Tint those wires with electrical solder, then fold them down against the wires insulation, cutting the excess of so that the wire ends do not extend past the circumference of the wires insulation, meaning..... holding the wire dead on, those tinted wires form a circle.
NOTE: Electrical solder is 60% Tin and 40% lead with a Rosin Flux Core, available just about anywhere.
Before doing any solder work on the brass terminal, check to make sure that the wire you've just prepared will slide into the brass terminal withough being forced.
With a hand held propane torch with a pencil tip, heat the brass terminal just hot enough to fill it with "Electrical Solder". Do not use any other type solder. Do not overheat the terminal. When the solder is a liquid, filling the brass cup, having the prepared spark plug wire handy, insert the prepared wire end into the melted solder within the terminal..... and hold it there for a few seconds to have the connection secure. That should take care of the screw in brass terminal end. Use "Caution" as that melted solder could spit out somewhat as the wire is shoved into the brass terminal.
The above procedure also holds true for the engines that have "Battery Capacitance Discharge" ignition, which is a fancy name for a battery operated powerpack.... quite a few engines in the 1968 to 1972 range. That would be the type that has one coil whereas the coil wire screws into a distributor cap located under the flywheel.
The rubber boot, spark plug end.... With the wire cut to the length required, trim back 1/4" insulation again but do not solder tint the wires. Simply fan out the wires and fold them back against the insulation, cutting the excess off as explained above. Holding the spring wire terminal, estimate where the prong should be inserted so that the spring will be flush against the exposed wire. Hold the spring terminal away from the wires end (sideways) and insert the prong into the insulation and into the center wire, then swing the spring terminal in front of the exposed wire portion (makes a tight fit for continuity purposes).
Spraying the inner portion of the boot where the wire will insert with a small amount of WD40 makes the installation of the wire a easy project. That's it.... you're done.
ctaylor2069
Thanks Joe. Now to process all this info and hope I dont screw up lol
ctaylor2069
Well I got the brass pieces unscrewed so now to order parts
Willyclay
Attaboy, those magneto caps are expensive. Good luck!
ctaylor2069
just ordered spark plug boots and the wire terminals. hope to have them soon. wish me luck boys and thanks for the help
ctaylor2069
Well guys just got parts today and followed the VERY helpful instructions and I think I might have actually done it right. Lol. Well its late and I won't be able to try them out til Wednesday but I'll let ya know if it works
ctaylor2069
How do I post pics?
ctaylor2069
OK guys. Got spark and sprayed a lil eather and still won't run. Any ideas?
Willyclay
Do not use ether because it contains no oil. Use pre-mix instead. Good luck!
ctaylor2069
Regardless any idea why its not running
boobie
Will the spark at the plug wires jump a 1/4" open air gap. Is the belt timing correct ??
ctaylor2069
Spark seems to be jumping just fine. I believe the timing is correct. How do u set the timing on one of these old motors. Also what's the mix ratio oil to fuel ?
boobie
The mix ratio is 24:1. Sorry I can't type long enough to tell you how to do it but maybe somebody like Joe Reeves will chime in.
OK, to set the timing..from memory..Turn the flywheel until the timing mark on the flywheel matches the timing marks on the block and recoil starter. Now advance the throttle until the notch on the distributor pully base aligns with the notch on the distributor bracket. The brass flat link is the adjustment point. The timing mark on the distributor pully should match the timing mart on the pully base. If not, remove the pully cover and timing belt and turn the pully until it aligns. First set of Points should just be opening. Now look to see if carb is just ready to open. In not adjust stainless rod to just start to open carb. The second set of points will open 90* later, so turn flywheel 90* and see that they do. There should be another timing mark on the pully base, for this event.
BTW - Those timing instructions were from my '59 Fat Fifty. However, most or all of it should apply to your motor.
Joe Reeves
Click on my name to the left and send me a PM with your email address included. I'll send you the factory service manual instructions. (Joe Reeves)
ctaylor2069
Joe tried adding you. Don't know how to pm. Could still use that manual.
F_R
Actually, the 75hp is a bit different. Align the marks on the flywheel with the block & recoil starter as said. Then align the mark on the pulley with the center of the safety switch button. Slip belt on & adjust tension.
That is for the magneto. Battery ignition is different. On those, the timing mark is on the distributor bracket. Align pulley mark with that.
Joe Reeves
Yea, okay, now I know what you were speaking of when you said "manual". It's actually the timing setup from the manual, not the actual manual. I need your email address... send me your email address via a PM and I"ll get it to you. And be sure to remind me that it's the timing set up for the old V4 75hp that you need. (Joe)
