crappiejig
Thread starter- Joined
- Nov 30, 2007
- 115
I have a qd-24,new to me, and the spent cooling water exits the motor at just above the lower rubber mounts,from 2 holes on either side of the exhaust housing.Is this normal or is the pumped water not making it to the powerhead? I inspected the impeller,but have not received the new one yet.The cylinder head seemed quite hot after the 2 minute idle run,with a few blips above idle.I am running champion j6j plugs,which looked fine after this short run.The motor has not been run for nearly 11 years.Thanks for any comments.
