1963 Johnson 10hp
mtfisher
I was just given a 1963 Johnson 10hp (Model#QP-24B) outboard and it had a little play in the prop. I pulled the entire lower unit apart and cleaned it in its entirety. The lower seal is shot and there are a couple other parts I would like to replace as I am putting the thing back together, can anyone tell me where I can get a schematic for this entire motor so I know exactly what parts it is that I am looking to replace?
Thanks
JB
Re: 1963 Johnson 10hp
nit picking, that is a QD-24
jbjennings
Actually, I believe a QD-24 IS a '63. i.e. '53 = QD-14 '56 = QD-17
I like to nit-pick a little, too.:):)
just messin' with ya':D
JBJ
eavega
According to the service manual, the QD-24 is a 1963. Stands to reason since my QD-21 is a 1960.
If we are nit picking...
-E
AndyT
You're right! I just looked it up. I thought because my RKL-25 is a '63, your's must be a '64.
mtfisher
Ok you guys got me and it is a QD-24, does anyone know what the B is for? When i looked it up it said it was a 1963 so thats what i am going off of. Is there a entire motor diagram in the manual that calls out which parts are which? Also what is the fuel mixture supposed to be for this particular motor?
eavega
The service manual contains exploded views of the major systems, although I have found a few differences between what the manual shows and what is actually in my motor. Between the OMC service manual and the Seloc service manual, you get a pretty accurate picture of what is in there.
The correct mix for this motor is 24:1
-E
