1963 Johnson 18HP Model FD 17-M Serial @ 23308??32
William D Sherman
Wish to change from long shaft to short shaft and believe I need following parts: shaft #308615: shift shaft #303098; water tube #303917. anybody know where to get them and has anybody tackled this coversion to short shaft?
F_R
Honorary Supreme Mariner
Re: 1963 Johnson 18HP Model FD 17-M Serial @ 23308??32
Are you serious? We swapped those things back and forth from long to short and back again nearly every time they got traded in or resold.
If it is a factory long shaft, there are a couple of shortcuts to make life easier. First, it is simple to just cut 5" off the water tube and reuse it. Secondly, you can measure down exactly 5" from the groove in the shift rod and use a chainsaw file to cut a new groove. It doesn't have to go clear around the rod, just one side for the connector bolt to go through. AFTER you file the groove, take a hacksaw and cut 5" off the rod. A whole lot easier than taking the gearcase apart and replacing the rod--and cheaper too. You can do the whole job in less than an hour. Now all you need is a short drive shaft and the bolt at the rear of the gearcase. They are wherever you find them.
William D Sherman
You said I could find it "wherever". can you suggest where to find that short drive shaft and any idea of what it should cost?
F_R
I would start with a free want ad on the Webvertize page at the Antique Outboard Club's website. Cost?? Hard one to answer. Anything from free to $50. Some guys there just want to help. www.aomci.org
William D Sherman
Found the short shaft...thanks !!! Now I am looking for the shift arm lever and/or connectors so that I can control the shift via the cable to the control box at front of boat. I have the control box but missing the remote shift linkage parts.
