SuperEnzo
Thread starter- Joined
- Dec 11, 2014
- 32
Hi I have a 1963 Johnson 18hp that Ive been working on for a little while. I bought this motor off craigslist from a guy that had trouble with it running at high speed and had disassembled the carb so we couldn't run it. I bought it for cheap and immediately set to work on diagnosing the problems.
I put in the oem johnson carb kit with a new float, took out the welch plug to clean the orifices and the entire carb with wires and cleaner, reinstalled welch plug, replaced high and low speed packing washers, new gasket between carb and powerhead. I synced the carb with the cam follower so that the butterfly just starts to open as the cam follower is centered on the line.
Adjusted the needles 1-1/4 turns out for the low speed and 1/2 turn out for high speed.
Running 24:1 fuel/oil ratio
Cylinder psi is 90 in each cylinder
I replaced the spark plugs and checked the gaps on the points (.020"), checked for good blue spark, made sure the leads aren't crossed or anything
replaced the impeller and lower gear oil with new seals on the screws
I rebuilt my original Johnson 6 gal tank (single line) and put in all new o-rings and things since it was leaking (you can see what I did in my posts about the gas tank)
Now I got ready to start her up: pulled full choke, set it in my large water bucket, primed the bulb until it got hard, set the the throttle to a little past the start mark and after 4 pulls she fired right up and idled very high with the choke on, probably about 3000 rpm so I disengaged the choke and let it start to idle down and it started missing and popping out the exhaust. What its doing is at idle, with no choke, is the motor is idling to about 1200 rpm then it will backfire with a decent pop out of the exhaust and then the rpms fall like the engine is shutting down and then the rpms will start to rise back to 1200 rpm and the cycle starts all over again. The motor will continue to do this until I shut it down. Also interestingly is that enriching the low speed needle by even 1/2 a turn out has no effect (as i had thought that it could be a lean sneeze). In addition to try and get the idle rpms down I unscrewed the idle screw all the way out and even removed it and it had no affect on idle rpms.
I tried the boat on the lake yesterday to see if the problem was related to running in my bucket but the same symptoms showed. I even tried to throttle up the engine and the stumbling and all over the place rpms followed as I increased the throttle. At one point while trying to get the boat up to mid throttle (trying to slowly roll up the throttle to speed) the motor completely died and backfired so violently that It rotated the motor from one side of the boat to the other (picture the tiller handle swinging from port side to starboard). Also the motor was severely underpowered it felt (perhaps running on one cylinder) and we were barely moving in my 14 footer with me and my buddy who are light even though I had the motor pinned at mid throttle and the rpms were up around 2500. The motor starts pretty easily with cold or hot (like 3 pulls cold and 1 hot) but runs like crap cold and hot (after idleing for like 5 minutes).
Possible problems: these are what I'm thinking but I wanted some opinions from members here.
1) Running on one cylinder/ one cylinder is intermittently cutting in and out = electrical problem
2) air leak - this would explain the surging and the crazy high idle with the choke on (I had a 2 stroke motorcycle with a base gasket leak that did this)
3) clog in the carb - I highly doubt with these simple carbs at this point
Im pretty stumped with this, I can get a video of this later if you need me to. Thanks for any help
-Ethan
-Ethan
