1963 Johnson 3hp Help :(
retdguy
Hi,
I'm working on a 1963 3hp Johnson outboard motor and just changed the water pump and noticed underneath the impeller housing there was some salt buildup in the veins. I decided to take the head gasket off to check the water passages out; 3 of the 6 bolts came out but the other 3 broke off right below the bolt head. If I can get the head off, I should have a lot of bolt exposed but I can't get the head off. I have the motor on its back with PB Blaster sitting in the bolt holes. I've been hitting it with a rubber mallet with no luck. I have 2 broken bolts on the bottom cylinder left side and 1 broken bolt on the bottom cylinder right side. How can I get this head off??? :confused:
Thank you.
- Bob
WN2712NJ
Re: 1963 Johnson 3hp Help :(
There are extractor devices for broken head bolts. They sort of resemble drill bits, only are spun in the reverse direction. You drill a hole in the middle of the broken bolt and then screw the extractor in as far as possible. Check you local auto parts store.
Soak everything in penetrating oil for a day or two before trying this. That is also good advice for avoiding this problem in the future.
Good Luck
-dm
boobie
Don't use any screw extractors 'cause if you break one off your can't drill them out. I'd try some ATF and Actone mixed up 50/50 and use that. Also some heat would help. Try a steel hammer rather than a rubber mallet as the steel hammer will shock the area better.
