1963 Lone Star 14ft rebuild need some help
brianteel
Anything that was wood as rotted out. i have pulled the floor and took some of the fiberglass off the inside of the transom. I pulled the cap and found the wood that is there has also gone bad. On the bow on the bottom there is a whole due to rubbing on the ground.
Question time:
What epoxy sealers should I use for the wood on the floor and the transom?
What is the best way to fix the hull that has been rubbed through? There is no access to it with out ripping up a stringer.
The edges of the cap and the full are splitting, Can I just use some fiberglass to reinforce that?
What grit sand paper should I use to sand the gel coat to smooth it out?
What primer is the best to fill cracks in gel coat from age?
Bob_VT
Re: 1963 Lon 14ft rebuild need some help
WOW.....many questions I see.
Take some time to read through these posts and 99% of those questions will be answered in detail ;) http://forums.iboats.com/showthread.php?t=288451
brianteel
thanks i found most of my answers in those threads.
