1963 Lonestar Imperia Restoration
mcon
Picked this boat up for free about a year ago and I finally have some free time to restore it. So far I've taken out the cabin walls and door and also the sink and cabinet that was inside the cabin. I have also taken out the rear seat supports. Tomorrow I am ripping up the deck which is very soft and rotted. Hopefully the stringers and transom aren't rotted.
Here's where the questions start becuase I am new to boating and especially restoring.
What is the best way to go about replacing the deck? Should I use pressure treated or non pressure treated plywood? What should I coat the plywood in to completly waterproof it?
Plenty of more questions will be coming but that should be good for now.
I can't figure out how to put pictures in the post so here is a link for the pictures:
http://s779.photobucket.com/albums/yy75/mconnolly1/Boat/
ezmobee
Re: 1963 Lonestar Imperia Restoration
Really cool boat!
You're on the right track with pictures. If they are sized to 640x480 or smaller you can just copy/paste the IMG code links that photobucket provides next to each picture into here.
ben2go
I am glad you decided to keep and restore her.
mcon
Ok so the deck is finally up ( I'll post some pics later). What's my next step? I've read different things to use to secure it in and water seal it up. Any suggestions?
mcon
tmcalavy
Check the soundness of the stringers, use a small drill bit to core sample each one here and there...wet shavings means soaked/useless stringers, dry means solid. Clean out the hull, lay in foam if you're going to...install a chase if you plan to run plumbing/wiring under the deck, then install resin encapsulated plywood deck fixed to stringers. After that you can start on the inside layout, seats, instruments, controls, etc.
mcon
whats involved with having a plumbing system for a sink? It had one originally with a spray hose but when I pulled it out the hose and drain weren't connected to anything.
mcon
I tried drilling into the stringers and as far as i can tell there is no wood, it seems like they are just fiberglass with metal strips. Is this a problem? Also I have the plywood cut for the deck. What type of fiberglass/resin/epoxy do I use to to seal the deck up?
mcon
So the weather hasnt been cooperatiing but the the deck should be going in with the next 2 or 3 days. Does anyone know... before i put the deck in... if having hollow only fiberglass stringers is a problem?
OV1961
The stringers are not a problem. That is the way it's supposed to be. I did the same thing you are doing to my Vacationer. I used 1/2" marine plywood and covered it with woven cloth/epoxy. Use stainless screws and pre-drill the holes thru the wood and aluminum strip.
You have a great boat! Thanks for saving her! :D
