leegoldring
Thread starter- Joined
- Dec 18, 2013
- 24
Just completed restoration of a 1963 Hydrodyne, and currently have the original MC1-4 (there were 4 MC1 versions in 63 alone). Don't have exact S/N as it was not at all visible, but know it is is the range 1534570 THRU 1684187. I would like to get some opinions on sterndrive replacement possibilities. By the time I replace rusted drive shaft, seals and other needs like worn forward/reverse gears, going to get very costly indeed. Tools to even work on these units are nearly impossible to come by. Biggest issue I assume will be refit of a new transom assembly? This current assembly will only fit this specific year - has a short yoke, even the EZ shift sterndrives 1 year later are no good. Engine in great shape and is a Merc 160 IL6. There appear to be plenty of Alpha ones available, but what would best approach be? Thank you for any and all advice.
