bimmerbit_93
Thread starter- Joined
- Mar 21, 2009
- 31
I had a posting a few weeks ago and now I can't find it. Sorry for redoing this. The motor is a 9.8 hp, Merc 110. Compression, spark and all are good. Leak down test was only 2% at TDC. The problem is that when I choke it, the carb leaks gas out the throat. I have had the carb apart 3 times rebuilding it and checking the float and inlet needle and seat. I also rebuilt the fuel pump. It will start when choked but will only run for a few seconds. Then with the choke open, it will start but only run for a few seconds. My last thread, someone mentioned (can't remember who) to check the reeds with the carb off. I looked up in there. This model has a round reed block around the crank. All I can see is what looks like maybe the side of the reed block. When I turn the crank, it doesn't turn. Am I looking at the reed block and if so shouldn't it be turning with the crank?
