1963 Mercury 500 50hp
bgc
Ensign
Re: 1963 Mercury 500 50hp
I sprayed the Diamond Archive clear coat on Thursday, now to wait till next Thursday to start reassembly. The shine of this product is amazing.
I also stripped the cowl and faceplate with Aircraft Stripper, took 5 applications to get it off.
bgc
Ensign
Painted the cowl and faceplate over the weekend while waiting on the clearcoat to cure.
And today I started the reassembly......
ShowMeGuy
Paint looks very good..... Gonna look good out under the sun!
bgc
Ensign
Thank you. I'm starting to have second thoughts about running it and getting that first scratch.......
brnschoneck
KROIL, I put it on every bolt and up the exhaust then let it sit for a week. Not one bolt broke and I removed each with a 1/4" drive ratchet.
I did not do a compression test until I started the tear down. The engine was heavily fogged when I did do it,giving false readings.
w
where do u get kroil???????
bgc
Ensign
I buy it at Champion Shooters Supply when picking up supplies,
Solvents and Cleaners : Kroil
Or Brownells stocks it,
KROIL | Brownells
Midway USA,
Kano Kroil Penetrating Oil Bore Cleaning Solvent 1 Gallon Liquid
or direct fron KANO,
Penetrating-Lubricating Oils
I was introduced to this product by some competitive high power target shooters. This is now the only product I use to get fouling out of the shotgun bore and for a soak in the rifle bores. Turns out it also work well for its intended use as a penetrating oil. However there is a downside to this IT TAKES TIME TO WORK.....I just used it again on another motor. Put it on the area, tap withe metallic object to set up vibration and walk away for a week....exhaust bolts come out, Dyna Float bolts come out, flywheel pops off(after beating the crap out of the puller)...
bgc
Ensign
We're getting closer to startup. Carbs are finished and in, distributor is in and will have Link-n-Sync done soon.
This is the old gal the Merc left the showroom with in 63'. A 63' Starcraft Jet Star. Pulled the trailer for sandblasting today......and then she gets a rework.
ShowMeGuy
Whats the plan for the ol' Jet Star? Just putting it all back to as it rolled off the showroom? Same color, interior?
bgc
Ensign
The Jet Star restoration will be a year long project.
New transom, floor, carpet, seats and dash will come before paint and trim. I did find an original era AirGuide flush mount compass and speedometer for her.
bgc
Ensign
Start up day!!! Before the oil and exhaust coated the new paint job....
bgc
Ensign
Not only is she filled with synthetic two cycle oil and needle bearing assembly grease but she also running on 16:1 ratio fuel.....
bgc
Ensign
Thank you.
I have an hour run time on the muffs so far. Now to get the boat fixed....
bgc
Ensign
I picked up another 1963 500 today, this one is an electric model.....this thread might drag on for many more years.....`
GA_Boater
It's time to move on to a newer 500. Like a 64 or 65, you have the 63 model mastered. :) Good work, bgc. :thumb:
bgc
Ensign
I learned a lot from your posts. Keep them coming bro!
Glad to hear that!
My goal is to put the information about the White Merc 500 out there so others can find it and learn what not to do...... Unfortunately my entire flotilla is in drydock. Gotta get one seaworthy so I can go fishin, next 500 is on hold till winter.
quicktach
Gas/oil mix at 50:1 or even 40:1 is good for the older motor. I believe it's best to clean or replace fouled plugs than do a rebuild. Use a good grade of outboard oil from Castrol or Quaker State.
