CatfishMN
Thread starter- Joined
- Jun 14, 2009
- 170
Hi everyone. I have browsed the site for awhile and have learned some stuff about my motor from other posts here. Maybe someone can help me with this?
So this spring I bought a used boat/motor combo. The motor turned out to be a 1963 Super Seahorse 28HP. The previous owner had set up remote steering and throttle on this boat, both of which work well. The motor also fires right up.
The problem I am encountering is this. When I shift it into forward and give it some gas, the shift lever 'jumps' from the forward position and seems to disengage the forward gear resulting in a huge loss of power. It still runs as if in forward, but at greatly reduced power. If I idle back, shift back to neutral, then back to forward, I get good power again until it again 'jumps'.
Has anyone ever seen this before? If you were to guess, does this sound like a problem in the remote shift or in the motor's transmission?
Thanks!
Thanks!
