1963Viking
- Joined
- Jun 1, 2008
- 2
I have recently purchased a 1963 Viking Inboard/Outboard, model number 25DE21V. When I first purchased the boat, it ran fine at idle speeds when trolling. After I filled the tank, I have found that the boat is sputtering at idle speeds, and even shutting off on me. I noticed that the fuel line had broken, and have since repaired it-but the problem remains. If anyone has some clues as to where to look next, I would appreciate it.
Here are some of the things I have noticed/done:
-I have mixed the oil and gas to a 40:1 mixture
-To start the engine (this also started to happen around the same time), I now have to pull the choke out full, attempt to start it (never starts), push the choke back in, then it starts. Originally I only had to try the key once or twice.
If anyone has any suggestions or advice, please let me know.
Thanks.
Thanks.
