Old Motor Fan
Thread starter- Joined
- Aug 14, 2007
- 16
Ok, I'll admit it...I'm stumped.
I have a 1964 3HP Johnson that hasn't run for MANY years. I dumped the tank, cleaned out the varnish, reassembled (with a fuel filter). Replaced both coils, points condensers, spark plugs. Disassembled and cleaned the carb, all ports (except those with compression plugs over them), installed a carb kit with new plastic float, new needle and seat, new bowl gasket, new low-speed needle packings. No high speed needle on this unit. Cleaned the fixed high-speed jet in the bottom of the bowl. Reassembled the carb and now I'm stumped.
I've got great spark. The motor will fire and run for 2-5 seconds and die. It usually will not re-start until I blow out the excess gas in the venturi.
It appears to flood out as I've got fuel bubbling up through the port in the throat of the carb. (New boss gasket around it in the bowl). It seems as if the fuel flow isn't being interrupted by the needle valve. I set the float level as indicated in many threads here, then tried slightly below level. Still flows fuel.
Is there another passage that I'm missing that will allow fuel from the tank into the bowl and up through the center jet? Am I correct in my assumption that the fuel should NOT flow continuously when the motor is not running?
Thanks in advance for the help.
