Evinrude Boater
- Joined
- Jul 6, 2004
- 1,148
The motor was submerged for several hours. The magneto, distributor, starter, generator and carburetor were totally disassembled, dried out and reassembled. The heads were pulled and the cylinders dried out, oiled and reassembled. It fired up immediately and idled poorly on fast idle. Warmed it up then shut it down to adjust the points. Took it to the lake to give it a good run. It started immediatley and ran poorly as before. Tried to idle it down to shift gears but it stalled. It fired a few times when trying to restart it then no spark at all. Checked the points again and them seemed to be fine. Pulled the coil and found small cracks in the plastic at the corners of the metal blocks that stick out both sides. I'm sure water entered the casing and it's probably fried but is there a method to test it before hunting for another one?
