I picked up a very clean looking 9.5 with a Glenn's Evinrude repair manual and after working on it I can get it started, however I cannot seem to keep it running.
The person I bought it from only had it a short time and said it was a 1964. It is Model # 9422R and Serial # E16740.
I have an almost new fuel hose and bulb I drained the tank and refilled with 1 gallon 87 octane and mixed it to 50:1. I pulled the top off the carb cleaned all the gunk out including the high speed and idle jets and the needle and seat, the float look old but good. I pulled the flywheel and inspected the points and they were about .010 and set them to .020 at the high side of the cam. The coils look ok and there is no oil to be found from the crank seal, everything is dry. I also pulled the plugs ad they look ok and are gapped at about .030.
I have also removed and cleaned the fuel filter and while trying to start it with the fuel hose off to the carb I observed it squirting fuel out of the hose so I think the pump is OK.
I also needed to replace the pull start cord and reset the recoil, and it works great now.
I set the low speed mixture at 1/2 turn as stated in my Glenn's Evinrude repair manual. The engine is sitting in a tank and after trying to get it started it only fired a few times. Next I used either, yeah I know hard on 2 strokes but I need to know if it would try to run. Well the answer is yes it tries! I will go for about 3-5 seconds before it dies, sometimes spitting and kicking as in a misfire or pre ignition.
I have also started it with 1 plug wire disconnected 1 at a time to verify that each cylinder is running.
Does anyone have an idea of what I may be overlooking? I need more info. I don't think I have missed too much but I am a bit new to the old 2 stroke world.
Thanks for the help
Gnarley
