1964 Chrysler sea king 8hp
Status
Not open for further replies.
skruff33
i have a sea king having problems with no spark,is there anyway to test the points and condensors n coil,,any sites or any 1 no how to set timing on this motor.
Or any 1 no were to get these parts cheap.any INFO IS APPRECIATED THANK U
zopperman
Re: 1964 Chrysler sea king 8hp
Franz Marine in St. Louis has chrysler parts... Check the points with a voltmeter, do a resistance test and see if you get more than one ohm when turning the flywheel by hand. points are probably bad and could use a cleaning.. had this same problem with my 70 horse chysler
skruff33
thanx just ordered new points condensors and coils ,thanx 4 your reply
jbcurt00
Where did you buy new points at i need some for the same outboard
MJ,
14yrs later dont expect a reply.
Start a topic about your Chrysler outboard and ask questions there.
Closed
Status
