1973Chieftain
Thread starter- Joined
- May 31, 2010
- 1,298
I recently bought an old donor boat that had a 1964 Evinrude 40 hp on it. I tried to start it by hooking jumper cables to the electrical cables, but the engine barely turns over. It does turn over, but a slight pause between each turn. Sounds kinda like "uh........huh. uh..........huh". I then tried hooking the jumper cables directly to the starter with the same result. Both times i had my truck running to jump it. Does this sound like a starter issue? If so, I have a running '65 33 hp Rude... could I just swap the starters out? Thanks for your ideas!
