1964 Fisherman 5.5 Thermostat and Gasket
JDusza
Need to replace the thermostat in my 1964 5.5 Fisherman.
Wondering about orientation of thermostat gasket; flange up or flange down.
Any advice?
Thanks,
J
Daviet
Re: 1964 Fisherman 5.5 Thermostat and Gasket
Isn't the gasket flat, don't recall them having a flange on the gasket, but it's been a while.
1946Zephyr
Well, take a look at the one you removed. Easy enough. They pretty much are set up, to where it goes in one way. The holes may not line up correctly if it's not installed correctly.
JDusza
My mistake. I have not defined the part correctly.
It is the "Seal, thermostat housing."
The "Gasket, thermostat" is indeed flat.
Cheers!
p.s., there is no old one ....
OptsyEagle
Doesn't the seal wrap right around the flat part of the thermostat?
JDusza
Yup.
I just know if I pick an orientation, it will be wrong.....
Davem3
can i have the model number, please???
F_R
It has sort of a "skirt" on one side. That goes down.
Davem3
although i believe it is flange up, i want to make sure 100% first
Davem3
part number 4# thermostat seal, flange UP
part number 6# gasket thermostat cap is flat, makes no difference GOES IN ONLY ONE WAY
went to my 6HP fisherman to check...............
JDusza
Model 5402B.
Flange up.
Thank you.
J
