Re: 1964 Gale 60 by Johnson - quiet since 1984 -compression/punch
Thanks Joe! Lang's Outboards had a 10 x 9 1/4 in stock! He said it seems to be the most popular prop with this engine, so we'll give it a shot. Does the smaller hub essentially give more prop surface?
What are thoughts on the carb? My carb kit did not come with the little circular plugs, and a couple of those were leaking - used a dowel the same size to tap them down and that seems to have solved that leak, but it is still weaping from the orifice plugs and the intake manifold gasket - should I have use some sort of sealer?
Should I be worried about the compression? 65-70 on all cylinders.
