Update: Tilting lever, associated locking assembly and elliptical cam ring that is molded into the lower foot
After looking at the picture I supplied in Post # 51 I decided to repair my broken tilting lever by adding a lower support rod and associated support tabs. Please excuse the poor welding job as it is not one of my better skills. Not too pretty but it works. I may get my buddy to powder coat it for me. Ha Ha
When the motor is set for
forward operation The cam ring position is on the
low side of the cam ring which disengages the locking assembly. No locking of the assembly is required in this position as the torque of the motor applies pressure to the transom of the boat and keeps the motor down.
reverse operation (turned 180 degrees) the cam ring position is on the
high side of the cam ring which engages the locking assembly. This is required as the torque of the motor wants to kick up the motor and the locking assembly keeps the motor from kicking up.
Note:
The tilting lever can only adjust the fixed angle of the motor while in the forward operation position by pulling up on the lever handle and moving the tilting lever to the appropriate detent position.
1964 Johnson JH19A 3hp Tilting Lever Lock Assembly (Open Position On Low Side Of Cam Ring)
1964 Johnson JH19A 3hp Tilting Lever Lock Assembly (Closed Position On Low Side Of Cam Ring) Note: That When I Depressed The Lock Assembly The Bottom Edge Is Now Away From The Cam. When Motor Is Turned 180 Degrees The Cam Will Lock The Lever.
1964 Johnson JH19A 3hp Low Side Of Cam Ring Allows Free Tilting Of The Motor In Forward Position.
1964 Johnson JH19A 3hp Tilting Lever In Forward Position (Lever Lock Is Disengaged) The Torque Of The Motor Keeps The Motor Against The Transom.
1964 Johnson JH19A 3hp High Side Of Cam Ring Engages Lock Assembly When Motor Is Turned 180 Degrees For Reverse Operation. This Prevents Motor Kick Up During Reverse Operation.
1964 Johnson JH19A 3hp Tilting Lever Repair. Please Excuse The Poor Welding As That Is Not My Strong Suit. I added The Lower 1/4" Diameter Rod And Associated Support Tabs. Not Pretty, But It Works. I May Get My Buddy To Powder Coat It For Me.
1964 Johnson JH19A 3hp Tilting Lever Lock In Position For Forward Operation On Low Side Of The Cam Ring.
