1964 Johnson 5.5 only start on fast
wadegreen80
I have a 1964 5.5. It will only start and run in the fast position. Even in the fast position it only runs low rpms. Any help is appreciated.
HighTrim
Well what is the compression?
is it running on both cylinders?
Will both cylinders jump a 1/4" gap on an adjustable open air tester?
Coils not original are they?
Possible stuck or broken shock absorber.
Many things to think about.
F_R
I'm betting on it's starting and running on one cylinder.
wadegreen80
Thanks for the advise. I have it running high rpm's, but now it dies when I turn the choke off
F_R
Dirty high speed jet in bottom of carburetor, behind the hex drain plug.
