1964? merc 500 no spark???
diesel69
Have the usual sob story, got used boat guy said it runs "it dont"
turns over fine but no spark. ser#1692302
any help greatly appreciated , wiring diagram would be great too just to make sure all is were its supposed to be.
Thanks.
MIKEY*2007
Re: 1964? merc 500 no spark???
click on top thread stickey what model /click on maxrules / click on tec specs and there you have wire dia
Laddies
Banned
If you remove the ground out wire from the side terminal of the magneto and still have no spark you will have to repair the magneto.
Taking the magneto apart (not removing the magnet rotor) is simple I would remove the cap and take a look cause it may be just burned/dirty/out of adjustment points and nothing else. Be careful not to forse or break anything. If the points are just a wee bit too wide it wont fire,but if they are right on the money the mag will be "hot" and should throw a strong bright spark 1/2 inch. Of course you need to inspect the rotor /cap etc for cracks but alot of wear often doesnt keep one from sparkin.
diesel69
THANKS SO MUCH EVERYONE FOR THE HELP.
Found the cap was cracked , points were rusted solid.
off to the parts store i go and then to the lake i hope.
thanks again.
