georgeJeff
Thread starter- Joined
- Oct 18, 2013
- 28
Like the title says. Let me make a long story short. Replaced water pump, copper tube came out of power head. Removed the "inspection" plate that the shift rod and the water tube pass through. It is held on with three screws, all three screws broke off during removal. Removed plate so that I could see the hole to replace the copper water pipe, pumps good water now. With the little plate came a rubber boot, gasket thingy. I thought and thought, asked a boat mechanic, and found now good reason to replace that little plate with its rubber boots, remember the screws broke. But, I have since read several post from folks complaining about a poorly running motor and they have been told to check the shift rod boot as it will make the engine run terrible.
Can anyone explain to me how this little boot can cause an engine to run badly. Makes no sense to me at all.
Thanks
Jeff
Thanks
Jeff
