Evinrude Boater
- Joined
- Jul 6, 2004
- 1,147
Was burning off gas before taking my boat out for the season and it siezed. Initially I thought I caught something in the prop but it was clean. Tried to turn it over with the pull cord but it was locked up. After it cooled it can be turned over by the recoil starter.
I haven't tore into it yet to see what the cause and damage is and I can't determine what it might be. I thought maybe the oil separated from sitting over a month but I did slosh it around a bit putting the tank into the boat. I used up another tank that was sitting for the same period with slow and WOT running with no problems. Maybe it overheated but I happened to be watching the tell-tale today as well as the exhaust relief. It seemed to be pumping well. The only thing I can figure is that the water pump flew apart and stopped pumping water rather quickly.
Where to go now? I'll be replacing the water pump but should I be inspecting the cylinders for scoring before trying to run it again? Or should I just run a compression test to see if there is a significant change?
I've got all winter.
By the way, I just finished the trailer two weeks ago completing this five year project to restore the boat, motor and trailer. Just when I think I'm done, I'm right back into it.
