georgeJeff
Thread starter- Joined
- Oct 18, 2013
- 28
Once again I come before the alter of ignorance. I have had a few post here about this "cheap" motor I bought to get some quality fishing time with my daughter before I become stupid and uncool. If you are a parent you know what I am talking about.
Finally got the silly thing running, and has a just fair idle. But just not right, stumbles, sputters, tries to die at idle, not a lean spit. S/S needle does respond, but does not seem real sensitive to adjustment, runs and idles best at 1.5 to 1.75 turns, will die at 1 or less turns. Seems pretty good at WOT in the barrel. New coils, points, condensers, plugs, plug wires, water pump, carb boiled out, very clean with a new carb kit. NOT a carb problem ( I don't think).
Newly noticed problem: The manifold (I think that is what it is called) on the drivers side of the motor (right side, starter side), the third bolt down has a steady stream of oil running down the side of the motor. My neighbor said that if this gasket it bad it could cause water to get on top of the piston and cause poor running. I removed the plugs and with a small light looked into the abyss at the pistons. The top piston is black, just like you would expect, the bottom is black on one side, but shinny on the other. Am i correct in thinking that cold water hitting the top of a hot piston would effectively decarb the top of the piston? Started the motor, and at a healthy rpm, pulled each plug wire, the top wire caused a pronounced drop in rpm, the bottom wire pulled, not so much of a drop in rpm. My neighbors comment, "the bottom plug is not firing hard enough". By the way, if your in the nashville TN area, you may know Larry Hagen boat mechanic, my neighbor worked with Larry for years, he knows a fair amount about outboards.
Thanks again ladies and gents.
