lakelover
- Joined
- Mar 26, 2003
- 4,386
Re: 1964 15' Starcraft Aluminum Runabout Project
Thanks, guys.
Vegas, looks like your plan would make a good solid transom, but as you say, no room on my boat. My original plan was to get that wood out and make a new piece that went straight across the top, but that piece is really in there. (BTW, what software did you use for your neat graphics? I'd like to be able to do something nicer than my "pencil and paper" software I used but without spending a whole lot of time on it. For me, when it comes to computers/time there gets to be a serious point of diminishing returns!))
My new piece would fit right in between the tops of the same heavy aluminum corner brackets that hold the transom & sides together, so it would have the same support on the ends as the bigger piece. Here's a shot showing the corner construction, good & hefty.
Albert, the motor has no clamps, but bolts on with 4 bolts. I know the ends will be well supported so if I can make a good solid connection between the two pieces of wood, I think it will work.
I am only guessing at the number of lag screws I would need, I don't know how an engineer who actually knows something about the forces involved would see it.
Thanks, guys.
