Re: 1964 15' Starcraft Aluminum Runabout Project & more pics
Today was a day of taking down, thinking and getting ready. Almost sounds like my old job. The Red Green Paint Booth that served me so well as a bird crap and rain shield, and took me half a day to put up, came down in half an hour.
I started out double checking my previous plans and thoughts about the dashboard and controls, and got sidetracked finding things I knew I had but wondered where they were. Also made a trip to Lowe's for supplies like SS fasteners that I only needed 2 or 3 of and had screwed up on my previous ordering...too short, not enough etc. Also got my 1/4" oak face plywood for the overlay. Once it's cut out, I have some epoxy resin left, so I'm thinking I'll throw some of that on before applying several coats of spar varnish.
I first double checked my dash template and tweaked those measurements. While looking over my Teleflex rack steering unit that I bought new a year ago, I found that they had shorted me one bolt and washer of the 4 that hold the two pieces of the rack & pinion unit together.
Anyway, on from that to rechecking fit & position of steering unit & wheel, and figuring where my tach/gauge and switches will go. The OEM tach/gauge unit requires a 3-3/8" hole, but try to find a hole saw in that size locally. So I got a 3-1/4 and will file it out by hand. I just measured it and it won't be much filing.
I had thought I'd reinstall the interior lower gunwale trim, but found that I don't have the right size rivets. Since Lowe's has a very limited rivet selection and I don't want to buy 100 at Fastenal when I only need a dozen or so, I'll drill out the holes a little & use some I have.
The only thing I did today that looks like progress was getting the control board installed. And to feed your insatiable desire for pictures, here it is. That Jo Ann's burgundy marine vinyl is a perfect match for the paint!
