1964 Starcraft Jet Star Aluminum Runabout Project
  • Rustoleum Marine
    Votes: 19 41.3%
  • Interlux Brightsides
    Votes: 16 34.8%
  • Pettit Easypoxy
    Votes: 11 23.9%
  • Total voters
    46
lakelover
Re: 1964 15' Starcraft Aluminum Runabout Project
Not much to report at the moment, but I wanted to mention that the Easypoxy seems to be holding up very well as I work around it with my tools. I've bumped it a number of times and cringed, only to discover that it hadn't scratched.
The only weak point, and too bad because it will probably take more abuse, is the splashwell, where I used gray auto etching primer, and put it on too thick. I already have a number of small scratches there. Must be all in the primer.
I should have the seats in later today.
lakelover
OK, the seats are in!
I fastened the seats directly to the seat boards, no swivel. I removed the screws provided and replaced them with full-thread SS hex bolts of the same thread, 2-1/4" long, from boltdepot.com. I had trouble with one of the T-nuts inside a seat, when I inserted the bolt, the nut just kept turning and eventually came out inside the seat. Luckily I was able to keep it located and put it back in place. To remedy that, I just put the provided screw back in and really cranked it with my cordless drill w/ Phillips head to draw the points into the plastic. Problem solved. I then did that with all the remaining ones before trying to mount them and after that things went smoothly. Quality control on these seats is not fantastic.
I made a template on the bottom of the seats that I could just place on the seat boards after measuring the location and mark & drill the slightly oversized holes. I didn't want to put 5200 on the bolts as I'm sure eventually the seats will need to be replaced. Instead, I coated the inside of each hole quick & dirty with polyurethane. That's a pretty well protected location anyway.
And one more shot of the helm completed:
Next is motor mounting when I get enough muscle here at one time. So close yet so far. :rolleyes:
yooperangler
Seats and dash look great !!!
jtrom
Looks awesome! Are those low or high-back seats????? I'm deciding which style I should get for my jet.
lakelover
I found that they came in all sorts of dimensions when I was looking. These are fairly standard and are 19-1/2" high at the seat back.
lakelover
Thanks, yooper, it felt like I'd never get to this point. I've been moving the boxes around in my house here and there for over a year as space was needed and finally got to throw them in the recycling yesterday!
GA_Boater
Always a good sign when you start to empty cardboard boxes, isn't it. And the room created makes room for new boxes filled with new goodies. LOL LL - you are setting a high standard for Jet Star re-do's. Simply stunning!!!!!!!!!!!
lakelover
Thanks.....but I think the "goodies fund" will be depleted for a while!! :D
lakelover
Can someone recommend a compact (short) come-along that I can use to lift the motor (200lb.) and may never use again (cheap)? My frame doesn't leave much room for vertical adjustment! Thanks.
lakelover
jasoutside
Well lake, it's rated for 1200# so it should lift your 200# OB. Barely:rolleyes:
Man, you are getting close buddy! Few more days of tinkering and she'll be ready for action!
lakelover
Yep, seems so close and so far. Have a feeling the motor is gonna stall me while I figure things out, never rigged one before.
jasoutside
Well lake, the OB guys are always trying to convince me of how totally awesome, and superior, and wonderful, and angelic, and smart, and reliable their drivelines are. With the way they talk you should just be able toss the controls, fuel lines, batt cables in the boat and it should hook itself up.
:D
lakelover
:D
Yup but I consider myself a rank amateur in that dept. Maybe when I get all the stuff I'll just throw it al lin the boat and come out in the morning and see if the outboard fairies have it all rigged & adjusted!
BTW, I hope you weren't put off by my reaction to the HF come-along above, I was seriously considering it, but still in stitches over the warning in the manual! I'll probably get something local in the interest of saving time. There seem to be a number of cheap-o's around $20. I had images in my mind of the HF one bending or breaking and dropping the motor, so as insurance, I'll get something I can hold in my hands and look at first!!
jasoutside
Heck no. Shoot, I have two HF come alongs hanging on the wall here in the shop totally busted up from being under worked!
lakelover
Found another picture of the seats:
OK, I'm done now.
Huron Angler
LL the boat looks great with the seats bolted in, excellent choice:D
I'll bet you are chomping at the bit to play with your new toy!
Good luck with the OB rigging, looking forward to seeing what she looks like on the water.:)
bananaboater
Ensign
You're making my eyes hurt again. Lookin real sharp.
lakelover
Thanks guys. A neighbor at the lake who knows about the project called it my "Corvette". Too bad, I never was into Corvettes though.
