1965 40 hp electromatic lower unit question
stevensmithnc
Ok so I got the motor running perfectly yesterday it runs really nice now the only problem is the lower unit. The prop spins meaning its in neutral, apply power to either the blue wire or the green wire and the clutches lock up perfectly so the electronics are good. The problem is that I cannot spin the main shaft that comes from the engine so it is frozen. What steps should I take and what do you think is a possible problem...Im hoping maybe some bad bearings or something that can be easily replaced
R.Johnson
Re: 1965 40 hp electromatic lower unit question
About the only thing you can do is take it apart, and see.
stevensmithnc
ok so i took it apart and the bearings in the lower unit midsection are all frozen. not the ones in the gearbox though. Where can i buy these parts?
R.Johnson
If you can take the number from the bearing, a bearing supply business may have them, or could order. A BRP dealer could tell you if still available. If so get ready for sticker shock.
