rolmops
- Joined
- Feb 24, 2002
- 5,750
After attaching the lower unit of this ancient beast,it will shift fine for a few times but then it will pop out.The reason for this is the shift rod which has a lot of up and down play.After checking a manual,the I came upon a part that is called:"bracket shift shaft hold down"(part # 37824) I checked and indeed,I do have this bracket,but it is not connected to anything.
So the question is. How do I connect this shift shaft hold down bracket to the shift shaft and how far do I have to take the engine apart to do this?
As always, your advice and opinions are highly appreciated.
