1965 90 HP Model 90-S Wiring harness????
nldubin
Could some one help. I have been able to map out all the wiring on the harness. But there is one wire I have not been able to determine what a large brown wire is to go. It is the wire that comes off a side screw attached to the alternator fuse. Located under a plastic cap.
Evinrude Boater
Re: 1965 90 HP Model 90-S Wiring harness????
I have a bunch of wiring diagrams but not specifically for the 90 hp. Some of the other diagrams for the 85 may be the same. Is the wire in the junction box? Are you certain its an alternator and not a generator?
nldubin
Thank you for your response. When looking through an old evinrude spec sheet, they indicated that my motor is a Battery ignition system. I also have a 1968 65HP sport four with a Magneto ignition sys which looks totally different.
The Plastic cap that covers the wire says remove cover to replace alternator fuse. I will attempt to attach some pics.
I just need to know what to connect the wire to. I personally suspect it is the wire that recharges the battery.
Thank you to any one willing to help.
Evinrude Boater
You earthlink photo link did not work.
Are you trying to connect the motor wiring to a different boat wiring harness?
nldubin
Hi if you high light the whole link including the ~nldubin/ it should work.
Well yes and no. The harness on my boat is the same but the motor on there now is the magneto type and has less wires on it. I was planning on adding the wires I need like the electric shift and such.
Thank you
F_R
3 brown wires come off the 60A fuse. One to a capacitor, one to the accessory power takoff terminal on the bottom of the junction box, and one goes up front to athe Gen side of the ammeter. The ignition switch Bat terminal is also fed by the same Gen terminal of the ammeter. Yes it is an alternator.
F_R
See if this works
F_R
They never work for me. If you want to post your e-mail, I'll send you a diagram that way. It's for a '64 but should work ok.
nldubin
To get the web page to work you can't just click on the link. You have to highlight the whole address and copy and paste it into the address section on your browser.
Hope this helps.
