cajuncook1
- Joined
- Sep 3, 2009
- 559
Re: 1965 Ducktwin won't fire
You assess the temperature of the motor on same side of the freeze plug (round identification plug with model and serial number). The reason for this is that the exhaust plate on the opposite side gets blazing hot as well as the cylinder head. You can use a infrared/laser digital thermometer or a temp stick. (You can get infrared/laser digital temp read for about $20 at Harbor Freights or even an Automotive store.) Running temp on the core plug side should not get hotter than 155 Degrees. There is not thermostat so water is constantly circulating around those water jackets.
