ChuckNorris
Thread starter- Joined
- Aug 14, 2007
- 12
Ok, i need to see why my prop is not spinning in neutral, however i don't know how to get the lower end off. So I have the plate that looks like a boot taken off the back, under the engine(the plate w/the exhaust hole in it), I have the next 8 bolts under that removed, (which is like a sleeve), and then i have the last row under that removed......How in the heck does the foot come off????? I noticed a diamond shaped plate on the left side of the engine, i removed it, then removed the next plate, and saw 2 bolts(as if it were the gear rod).....is it those 2 bolts that will let the lower end drop off??????? I've been out here working now for like 3 hours, so any help would be GREATLY appreciated........
Chris
Chris
