1965 gimbal ring hinge pins
65holiday
65 1aez, having problems accessing aft u-joint bellows clamp nut, someone put it on top! if i pull the gimbal ring hinge pins i think i can lay it back enough to make access, how tough are these to pull?
Fishermark
Re: 1965 gimbal ring hinge pins
Easy to pull if they are not corroded up. You will need to straighten and remove the aluminum "nail" holding them in and then pull them out. You can screw a bolt in them and they should pull right out. Otherwise you can use a slide hammer.
65holiday
your on it sir... that worked great...i don't suppose perfect seal is a substitute for bellows adhesive,or is it?
Fishermark
No, but 3M Weatherstrip adhesive is.
65holiday
excellent , i'll try to find some ,thanks... going to "diy" for gimbal puller and tips
